Dodge Ram Lamp Out Warning
SCHMIDZ
we have a 2002 dodge ram 1500 with 194,000KM on it. keep getting intermittent "lamp out" warning. the bell will sound but not display the lighted "lamp out" until it has chimed 4-6 times first. then will keep chiming without the "lamp out" lit up. very random, nothing that it sparking it. will happen then stop for a few months, then happen again. all lamps are fine. any idea re what it is?
Apr 26, 2007 at 7:02 AM
TAZ12345
I have a 2003 dodge ram 1500 V8 4.7 with 38,000 miles on it. Keep getting intermittent "lamp out" warning. The bell will sound and display the "lamp out" message. It just started doing this today 7/30/2007. I checked all my lights and they are fine. Please help me, I dont know why this is happening.
Jul 30, 2007 at 12:56 PM
DPWD23
  • 136 POSTS
either you have a grounding issue or a bulb is "about to go" meaning that the filiment is cracked, but when sitting still it is still making contact.
I would let it go for a few weeks with lamps on full time to get the troubled bulb to finally quit, or take it to a shop to have them further diagnose the problem.
Aug 2, 2007 at 5:37 PM
Suggested Repair
Check for a poor ground or a bulb with a cracked filament that still makes contact. Run the lamps continuously for a few weeks so a failing bulb fails completely, or have a shop diagnose the circuit.
Conversation Summary
Owners of 2002 and 2003 Dodge Ram 1500 trucks reported intermittent lamp-out warnings and chimes even though all lamps appeared to work. An expert said the cause is likely a grounding problem or a bulb filament that is cracked but still contacting, and suggested running the lamps full time until the weak bulb fails or having a shop diagnose it.
