front rotors
CMACK69ER
how difficult is it to change th efront rotors on a 1994 dodge ram 1500 4x4? is it as easy as the rotors on my camaro?
Apr 18, 2007 at 10:19 AM
LSUSSEL
  • 252 POSTS
you need to remove the caliper and brake pads, if you change the rotors, you must as well change the pads, sometimes the pad form to the rotor and if the rotor is warped and what not...it would be forming to the old rotor which wouldnt be the same width and the new rotor and could cause problems
Apr 20, 2007 at 4:13 PM
