2000 Dodge Ram Check Gages Light
RAVENLOVELY
i drive a '00 dodge ram 1500 and while i'm driving the check gages light turns on
Feb 1, 2007 at 5:31 PM
GARFIELD
  • 197 POSTS
My 02 durango did the same thing and it ended up being that the battery was going bad, but of coarse the first thing I looked at when I saw the light was the oil pressure gage then the temp and that was when I noticed the battery light pegged low.
Feb 1, 2007 at 9:00 PM
Suggested Repair
When the check gauges light comes on, check oil pressure, coolant temperature, and the battery/charging gauge. A weak battery or low charging voltage can trigger the light, so test the battery and charging system.
Conversation Summary
The owner of a 2000 Dodge Ram 1500 says the check gauges light comes on while driving. A reply describes the same symptom on a 2002 Durango caused by a failing battery, and notes that oil pressure, temperature, and the battery gauge should be checked; the battery gauge was reading low.
