Check Engine
BBKAT1112
1997 Dodge Ram 2-wheel drive 5.9l engine..
Check Engine light came on.. checked diagnotic code using ignition and counting flashes.. code 33.
What does that mean?
Sep 16, 2007 at 4:54 AM
WRENCH
  • 57 POSTS
Code 33 is your a/c clutch check to see if your a/c works correctly, if so than don't worry it will proble cycle off on its own or you can erase the code and wait to see if it comes back. If you have a problem with your a/c check the fuses frist.
Sep 18, 2007 at 6:16 AM
