2004 Dodge Ram Speedometer and others not working
42,000 MILES • V8 • 4WD • AUTOMATIC
LWGENTRY
I just bought a used 2004 Dodge Ram. The battery was dead when I wanted to test drive it so the dealer jumped it off. Everything worked fine while test driving. While negotiating, they had a new battery put in it. When I left the speedometer, odometer, and the overhead digital mpg monitor were not working. However, the tachometer is working. Any ideas what is wrong. Thanks!
Dec 29, 2007 at 11:12 PM
MWOLOWS803
disconnect the battery and re connect it to see if reset it if not check the fuses if it a 4.7 liter check fuse 28 and 51 if they are ok you might have to get the cluster reprogramed to the truck
Mar 13, 2008 at 5:05 PM
