1991 Dodge Ram speedometer doesnt work, sensor on trans is
98,000 MILES • 6 CYL • 2WD • AUTOMATIC
SPROUSE99
speedo doesnt work, has good ground, 5 v ref is present, sensor shows a fluxuation in resistance when spun by drill...any way i can be sure it is guage?
May 20, 2009 at 8:02 AM
MMPRINCE4000
  • 8,548 POSTS
Well if you can find a scan tool for the car, you can hook up to diagnostic terminal, go to live data and scanner should display speed (when driving). If it does, the gauge is bad, if not then sender OR wiring from sender to gauge.
I would go to junk yard and look for a 91 Dodge and get sender and entire IP, probably would be the cheapest route.
If you find one, get trim pieces, sensors, whatever you can afford.
May 21, 2009 at 12:45 AM
