2004 Dodge Ram check engine light
TYLYMAN
  • 2004 DODGE RAM
  • V8
  • 104,000 MILES
Light came on, engine stalled then restarted 3 fault codes p2106, p0340, p0335 are these codes related to each other? One is throttle control the other two are camshaft positoin sensors dealer said replace the pcm but want to make absolutely sure. Vehicle hesitates a little and runs crappy before stall that has always happened during a slow down or stop
Sunday, November 15th, 2009 AT 12:31 PM
DIXIEGIRLSINTN
I have an 04 dodge ram with a hemi, only problems I had like that were because of crappy gas or the gas cap not tightened.
Tuesday, November 24th, 2009 AT 2:38 PM
DOCFIXIT
  • 18,828 POSTS
Hi
2106 is trigered by a fault and PCM reduces power ie. Runs crappy part. The 335 - 340 are crank and cam sensor fault. If either one fails then both codes set and PCM reduces power. A diagnostic test is needed is this what Dealer did? If yes then if sensors check out and wiring is good then PCM is faulty.
Hope this helps
Thanks for donate
Tuesday, November 24th, 2009 AT 3:05 PM
