2003 Dodge Ram Brake Lights
DENO3DDD
  • 2003 DODGE RAM
  • V8
  • 13,270 MILES
I recently had an issue with my brake lights consistantly staying on even when I turned my truck off. I replaced the Brake Sensor under the dash connected to the Brake Pedal. Now it only stays on when the truck is running. Now when I am driving, my brake lights are always on, which does not make me a popular driver on the road. Is there a step that I am missing, or can it be something totally different?
Thanks,
deno3ddd
Sunday, March 22nd, 2009 AT 7:16 PM
CARADIODOC
  • 33,916 POSTS
The new switch is supposed to auto-adjust when it is installed. If it is over-adjusted, push the brake pedal down, then pull the plunger all the way out. Push the plunger back in 4 clicks. Release the brake pedal and pull it back lightly. The pedal will adjust the switch plunger. If the brake lights still stay on, check the bracket the switch is mounted to for being loose, bent, or out of adjustment.
Caradiodoc
Monday, March 8th, 2021 AT 12:21 PM
