2000 Dodge Ram abs light and brake light.
125,000 MILES • V8 • 4WD • AUTOMATIC
JERROD802
The abs and brake light havew been coming on and going off. The speedometer works fine, but when i am just driveing down the road i can hear the abs noise under the hood. And when i tried to stop the other day, the brake pedal could not be pushed and i had to slam it in park to get stopped. Also i noticed when the lights are on i have no abs, brakes lock up on snow. What is my problem?
Feb 24, 2009 at 4:23 AM
MIKE H R
  • 3,094 POSTS
what it sounds like is the abs unit itself is messing up and not releasing the pressure. you can try disconnecting the electric to the unit, the abs light will be on but this is to check it. drive a little then try the brakes. If they still lock up then the abs unit should be replaces. these units are expensive so shop around and see if you can find one at a local junk yard.
Feb 26, 2009 at 2:19 AM
JERROD802
Where is the abs module located?
Can I just uplug it and leave it unplugged?
I do not like abs anyway. Would my brakes work correctly with this unplugged?
Feb 26, 2009 at 4:11 AM
MIKE H R
  • 3,094 POSTS
you can unplug the abs but the brakes will work like the brakes in older cars without abs. you can disconnect the abs electrical connections and the brakes should work like normal without abs. One thing is that even with the abs disconnected if the portioning valves in the abs unit are bad the brakwes could still lock up, try disconnecting them and see what happens. I do suggest that you have them repaired when you have the chance.
Feb 27, 2009 at 12:00 AM
JERROD802
if i unplug the abs unit, then of course the brakes are going to lock up, correct. because the abs will not kick in if it is unplugged?? I don't understand, i will try it tonite anyway.
Feb 27, 2009 at 12:30 AM
MIKE H R
  • 3,094 POSTS
the brakes should not lock up unless there is a problem with the porpition valve in the abs unit itself. with the electri connection disconnected the abs system will not work, that means when you step on the brake it will not pulsate to keep you from skiding, that is what abs does. With out abs the brakes will work like normal brakes, if they do lock up the valves in the abs unit itself is not working releasing the pressure when you let off the brakes, I just did a 1999 blazer that did the same thing and Even after disconnecting the abs the brakes would grab, that was because the portioning valve in the abs unit itself went bad. you will find the abs unit if you follow the brake lines comming from the brake fluid resevior. it will have two lines going into it and 4 lines comming out of it.
Feb 27, 2009 at 1:10 AM
JERROD802
when you say "lock up" are you talking about the brakes/wheels or the brake pedal?
Feb 27, 2009 at 4:27 AM
MIKE H R
  • 3,094 POSTS
the brakes work independent from the abs. If a abs unit fails then you will not have antil lock brakes { the part that keeps you from skidding. Alol the abs unit does it pulsates the brakes to keep it from skidding. If the abs unit is bad and the porpotioning valve is bad the valve could keep cause it to lock up.
Mar 8, 2009 at 1:19 AM
