You definitely blew a fuse, however which one is the question. You have 2 fuse blocks, one inside the truck the other one is inside the engine compartment you also have a few different fuse types. This happened to me at one time and I blew the same fuse I think? The in truck fuse panel is accessable when you open your front drivers door, there is a little pannel between the dooe and the dash it has a little finger type indent so you can pop it off, I would check your accessory fuse to see if it is blown you can tell because the little U shaped metal piece is in 2 parts instead of one, the second fuse block is inside your engine compartment king of either in front or behind the battery. There is a knob that you unscrew to remove it and then look at the fuse tops to see which one is burnt out, then go to the auto parts store and pick up one or two so you have a spare for future use OK? Let me know if this helps OK?
Bill
SPONSORED LINKS
Wednesday, September 10th, 2008 AT 3:10 PM
