2002 Dodge Ram Interior Lights
100,000 MILES • V8 • 4WD • AUTOMATIC
BP22HOT
Ok, when its really cold and I open my door, the interior lights come on for 1 sec and then shut off, any other time they do not come on at all. I assume this is gonna be a door switch problem. The only problem I can not find where the switch is located at. Thank you in advance
May 18, 2010 at 3:58 PM
BLUELIGHTNIN6
  • 16,542 POSTS
each of your vehicle's doors has a door ajar switch. the door ajar switches are attached to each doors lock motor which is inside of the door's trim panel.
May 18, 2010 at 4:08 PM
BP22HOT
Thank you, I thought I was losing it
May 19, 2010 at 7:29 AM
