2002 Dodge Ram
DACKMADDY
  • 2002 DODGE RAM
Drive Train Axles Bearings problem
2002 Dodge Ram 6 cyl Four Wheel Drive Automatic 85k miles
I cracked my transfer case, snapped my front shaft and most likely mess the front gears all up. Is it possible to drive for a couple of weeks while I get the money together to fix it.
Tuesday, January 26th, 2010 AT 8:15 PM
  • 109,885 POSTS
If there are no leaks and you have removed the front drive shaft, it should be okay, but remember, I'm not there to check it. Make sure there is no noise coming from it that may indicate the possibility of it locking up on you.
Tuesday, January 26th, 2010 AT 8:37 PM
