If you have a seized pulley, it can have similar symptoms, it can also happen if the belt is too tight. Typically, on occasions like this the belt will break due to being too tight or having a pulley seized.
The issue might not be related to the fan clutch at all. It could be the engine is in low power mode or limp mode due to other components.
An engine can have low power due to a clogged air filter, weak fuel pump, faulty mass air flow senor. It can also have sluggish acceleration due to a plugged catalytic converter.
Here is a helpful guide that covers the basics:
https://www.2carpros.com/articles/engine-has-low-power-output
Got through the list and report back your findings.
Is your check engine light illuminated?
If scanning and retrieving the code(s) can help with the diagnostics.
SPONSORED LINKS
Saturday, January 8th, 2022 AT 9:55 PM
