2001 Dodge Ram Failed Emissions
129,000 MILES • V8 • 4WD • AUTOMATIC
THE LEMONATOR
My truck just failed emissions for the first time ever and unfortunately it failed all three batteries of testing. The readings were: HC 1.3499 (limit 1.200), CO 15.1514 (limit 15.000) NOx 4.3165 (limit 2.000). The CO2 reading was 571.549. The truck runs great, I am at a loss as to what to do next - the check engine light is not on. The tabs in the back of the air filter housing are broken which is preventing a good seal but other than that I'm not sure where to start.
May 4, 2010 at 4:21 AM
RACEFAN966
  • 5,029 POSTS
Ok here is what I would try. I would change the oil and then put Seafoam in the tank and before going back for the test make sure you get the truck to full operating temp. You didn't fail by much so if the oil is at all old it could help to drop it enough to pass. Also check the air filter make sure it is clean.
May 6, 2010 at 3:38 AM
THE LEMONATOR
[quote:bbdf2f25ec="racefan966"]Ok here is what I would try. I would change the oil and then put Seafoam in the tank and before going back for the test make sure you get the truck to full operating temp. You didn't fail by much so if the oil is at all old it could help to drop it enough to pass. Also check the air filter make sure it is clean.[/quote:bbdf2f25ec]
OK- a couple of questions - It would appear I failed the NOx by a tremendous amount although I would agree that I just barely failed the other two batteries. The oil and air filter were good at the time of the test but I did go ahead and change them out already. I live in Colorado where you are tested by mobile units throughout the year and only have to go to an emissions station if you fail your last mobile test. Is there a causation specific to NOx that I should be looking for?
What is Seafoam? I did go ahead and put an oil treatment in with the new oil change and air filter and I cycled some gum out x2 through the fuel tank. Thanks,
May 6, 2010 at 6:57 AM
RACEFAN966
  • 5,029 POSTS
Ok seafoam is a oil or gas adative that works great in cleaning up the carbon build up that can get on the valves with today's junk fuel. Look them up on the net. I also need you to make sure there are no exhaust leaks and check the EGR for any leaks as these will cause the NOX to be high. Let me know what you find.
May 7, 2010 at 1:53 AM
