2001 Dodge Ram Coolant leak
117,000 MILES • V8 • 4WD • AUTOMATIC
KLDDET
This is the 5.2 liter Dodge motor. I have a coolant leak after the truck warms up. I cannot find the leak anywhere. It is originating from the motor, and not the radiator. The hoses are fine, and I see no evidence that the leak is coming from the connection where the thermostat is. It seems to me that I probably have a bad water pump, and using the Haynes manual I attempted to check this out and possibly repair it. Problem is that I cannot remove the fan. The picture in the book looks nothing like my truck. The manual says I need a 36mm fan wrench, but I do not see where I am supposed to use it, the nut on my truck is an inch and a half wide, not thin like the fan wrench. So how do I remove the fan?
May 6, 2009 at 6:43 AM
  • 110,246 POSTS
Is the fan clutch the problem? There is a special tool. However, I usually take the 36mm open end and (leave the belt on) smack the wrench with a dead blow hammar. After 3 or 4 hits the nut comes loose.
Since yours sounds different, is it possible to take a picture and upload it?
May 12, 2009 at 2:06 AM
KLDDET
jacobandnickolas-
Thank you for your reply. I ended up having the job completed at a shop, and alas I still do not know how they removed the fan. I actually did take pictures to upload for my original post but they were of such poor quality that I decided not to. The bolt in the manual was very thin like the fan wrench, however when I looked at my motor, the corresponding bolt was an inch or more wide. As you can probably tell, I am a newbie, and I may have been looking in the wrong place - although I don't think I was! In the end, it was a bad waterpump and I am in good shape now. Again, I do appreciate your response. Thank you.
May 12, 2009 at 6:28 AM
  • 110,246 POSTS
You were looking at the right bolt. 36mm and about 1" wide between the fan clutch and the water pump pulley. There is a special tool, but they are a pain to use. And, if you rent one from the parts store, it won't work on a Chrysler even though they say it is universal. The easyiest way to remove the clutch is the way I described. Trust me, I've tried many ways.
Regardless, I'm glad you got it fixed. If you have questions in the future, let us know.
May 12, 2009 at 6:35 AM
