2001 Dodge Ram code
2001 DODGE RAM
212,000 MILES • 6 CYL • 2WD • AUTOMATIC
LITTTLEREBEL13
engine light not on... going down road and it shut off... no gauges...dont hear fuel pump...code said no bu5
Apr 19, 2009 at 3:33 PM
BLUELIGHTNIN6
  • 16,542 POSTS
I believe what you say in the message was "NO BUS"..The "BUS" is the system Chrysler uses for it's computers to communicate on this truck. The error in the odometer means that the cluster is not receiving any messages. Any of the computers on the truck can bring down the BUS. ie pcm, abs, airbag, ctm, cluster, overhead mssg center, etc... The wiring in between can also be the cause. The most common solution to this problem is to remove the gauge cluster and clean the contacts of the cluster. The application of dialectric grease to the electrical contacts will also help greatly.
Thanks for using 2CarPros.com!
Apr 19, 2009 at 5:45 PM
