2000 Dodge Ram fuel pump safety switch
ANDY0888
Electrical problem
2000 Dodge Ram 6 cyl Two Wheel Drive Manual
i was playing in a field and sideswiped a tree and i think i tripped the fuel pump safety switch and don't know how to reset it
Jan 10, 2009 at 3:23 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Dodge doesn't use an inertia switch. The fuel pump is controlled by relays powered by the computer. Check the automatic shut down relay on the power distribution center, in engine compartment, on left inner fender panel near battery. If okay, check all other fuses and relays as well.
Thanks for using 2carpros.com!
Jan 10, 2009 at 3:53 PM
