2001 Dodge Ram ball joint/ rocker arm
2001 DODGE RAM
127,000 MILES • V8 • 2WD • AUTOMATIC
CHRIS PLATT
My son bottomed the truck out on a culverted drive bending the stem of the ball joint. The joint is riveted to the rocker arm. Can the ball joint be replaced or do I have to replace the entire rocker arm?
Jan 30, 2009 at 7:07 AM
DOCFIXIT
  • 18,828 POSTS
As long as control arm is not bent then you cut rivets and replace ball joint. New one will bolt on.
Jan 30, 2009 at 8:15 AM
