2001 Dodge Ram Ball joint replacement
2001 DODGE RAM
213,900 MILES • 6 CYL • 2WD • AUTOMATIC
CHIMPY81
How do i change out ball joints? Do i need to drill out the rivet tpe fasteners or what? I have the new ones and they are made to bolt in place of the old ones. Im lost.
Apr 6, 2009 at 2:25 PM
CARADIODOC
  • 34,383 POSTS
Professionals are trained to do this work without destroying other parts. Only the upper ball joints are riveted in. Due to design tolerances, you will need to have the truck aligned after replacing the upper ball joints. No respected mechanic is going to align it without inspecting your work since he is staking his reputation on the outcome, and he knows he will be blamed for any problems that arise later. You are better off letting him replace the ball joints. Each upper one takes about a half hour. The lower ones require a special ball joint press and take from one to one and a half hours each.
The mechanic will also perform a complete inspection before aligning the truck. Any worn parts that prevent holding the wheel and tire in proper position will result in tire wear and handling problems. He knows that aligning a truck with worn parts is a waste of your money.
caradiodoc
Apr 7, 2009 at 3:44 AM
