2001 Dodge Ram 01 Ram will not idle
2001 DODGE RAM
NOGADE
Engine Performance problem
2001 Dodge Ram V8 Two Wheel Drive Automatic 102k miles
Ran fine yesterday, however when I went to start it this morning, it just started clicking when I turned the ignition key on, cleaned the battery posts and reseated them, started up fine. Backing out of the drive it died on me when I took my foot off the gas pedal, restarted, pulled back to where I left from and held the gas pedal down to keep it from shutting off, put it in Park, revved it a couple of times then slowly took foot off gas pedal and it died again, will not start if I dont press the gas pedal. Hope you can help me with this one! First problem ever! Thanks.
Norman
Apr 12, 2009 at 9:14 AM
  • 110,244 POSTS
Has the check engine light come on? Also, have you checked foir vacuum leaks?
Apr 19, 2009 at 6:52 AM
BLAKESFIRSTT
  • 32 POSTS
I have a 98 and that same thing happened to me...but after i held gas down for a min it started idling just fine and haven't had prob since....so i would also like to know what this fix is 2....just in case i need to fix it in future....I"m not sure but I heard someone say something about a Ics (idol control sensor) or something close to that....and that would be my first guess if there are no vacuum leaks
Apr 19, 2009 at 9:06 AM
  • 110,244 POSTS
The Idle air control (IAC) or throttle position sensor (TPS) can cause it. That is the reason I asked if the check engine light came on. Normally, the bad item sill set a code in the computer. Once the computer is scanned, it will identify which is the problem.
Apr 20, 2009 at 10:07 AM
