when using the a/c or heater with the fan and I increase my driving speed they will stop working. As soon as I ease back on the gas pedal they will start working again.
Sunday, April 18th, 2010 AT 5:50 AM
MECHANIC
DO you mean the fan shuts off or does the direction change from (for example) vents to defroster?
SPONSORED LINKS
Sunday, April 18th, 2010 AT 10:11 PM
ROADKINGHD
MEMBER
The fan shuts off.
Monday, April 19th, 2010 AT 6:03 AM
MECHANIC
Start at the fan motor itself. Chances are there is a short or loose connection.
Let me know what you find.
Monday, April 19th, 2010 AT 6:45 AM
ROADKINGHD
MEMBER
I checked the fan and also r and r it and found nothing wrong. I was told that there is a resister that is part of the wiring make-up and it may not be working properly. Have you heard of this and could this be part of the problem. Kevin
Monday, April 19th, 2010 AT 11:19 PM
MECHANIC
There is a blower motor resister. However, when they are bad, usually the only thing that happens is the fan will only run on high speed. It is sort of a default setting. The slower speeds will not work.
SPONSORED LINKS
Tuesday, April 20th, 2010 AT 7:07 AM
ROADKINGHD
MEMBER
Do you have any suggestions to solve my problem. Thanks
