2001 Dodge Ram hestation at any speed
249,000 MILES • 6 CYL • 2WD • AUTOMATIC
EDWARD CZAJKA
when driving the truck feels like your running out of feul then goes again. if step on the gas pedal it goes .
Jul 5, 2010 at 12:08 AM
  • 75,988 POSTS
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jul 6, 2010 at 3:18 AM
