Death wobble
1999 DODGE RAM
RDF
Four Wheel Drive Automatic 140000 miles
My truck is a v 10 I believe a factory lifted 4/4 1999 I had the power steering replace and when I picked it up I couldn't drive it for more than 35 mph the steering vibrated so much I thought I was about to die because the wheels would fall of soon
I understand this is called the death wobble and can be caused by a number of front end issues can you suggest the most common fix and what I should look for when determining what should be replaced
Aug 26, 2010 at 12:23 AM
This issue is common on a twin I beam suspension set up when something in the steering, suspension, or tires are worn.
Here is a guide that will talk about some of these items but not all:
https://www.2carpros.com/articles/steering-wheel-shakes-when-accelerating-or-braking
The most common cause of this is a weak steering dampener or a worn tie rod end so those need to be checked first. Next is tires so rotate them front to back and see if the issue goes away.
Lastly, I am not sure which truck you have but I am not aware of any factory lift kits so if the truck is lifted, it is most likely aftermarket. If that is the case, then this needs to be checked as well for correct installations.
To check the dampener, we need to remove it and see if you can move it by hand. If you can then it has failed and needs to be replaced.
Please run through this info and we can go from there. Thanks
Mar 21, 2022 at 7:15 AM
