1998 Dodge Ram Surging Idle
174,000 MILES • V8 • 2WD • AUTOMATIC
BACON21
  • 10 POSTS
I have checked all the vacuum lines, there's no restriction any where. I don't see any leaks and I have been through 2 tps sensors, my idle randomly surges and when in park just runs up to about 3 thousand rpms the cat is bad I'm sure but what could cause this all the electrical connectors also read 5.0v give or take so i dont think i have to much power anywhere. i'm really stuck on this one.
Thanks,
Aug 4, 2010 at 3:56 AM
  • 110,245 POSTS
If the catalytic converter is bad, replace it before there are new problems. Have you checked the idle air control valve (IAC)?
Aug 5, 2010 at 5:10 PM
BACON21
  • 10 POSTS
I cleaned it, i also did a vacuum test today while at work, 25inhg steady i also have noticed that when i go to park it will hang at 3krpms for about 3 secs than idle down at normal
Aug 8, 2010 at 3:01 PM
  • 110,245 POSTS
did cleaning the iac change it a all? Also, have you checked the tps?
Aug 8, 2010 at 6:10 PM
BACON21
  • 10 POSTS
yes the tps is new it's actually the second new one thats been in there. i feel the IAC may be bad is there nay good way to test it to see if it's working properly?
Aug 10, 2010 at 6:29 AM
  • 110,245 POSTS
You should be able to see it working. Often times, if you remove them and clean them, they work again.
Aug 10, 2010 at 5:11 PM
