Radio not working
RICK HILL
  • 5 POSTS
Caradiodoc, thanks for replying to post. I will try what you said and I also suspect maybe it is in the ignition switch, again thanks for your input.
Sunday, July 22nd, 2018 AT 11:38 AM (Merged)
THOSFREEMAN
  • 6 POSTS
That would be great. I did not put the clip/cover back on. I simply stuck the fuse back into the socket. Makes me think though that the clip is something to insure that the fuse does not pop out. Aside from the clip, the fuse location itself is spaced differently from all the other fuses as if this was some kind of special fuse. Anyway, will look forward to hearing from you if you are able to find out anything about the clip/cover and uniqueness or extra importance of this particular fuse.
AUSTIN ROBBINS
I have an 2002 Dodge Ram 2500 long bed 4 wheel drive 5.9 gas. Fuse number 12 keeps blowing and from the diagram I have seen it is my constant 12v for radio and dome lights. It mainly blows when I open the driver door. I am trying to trace the short but can't find real schematics. Any help or suggestions?
Wednesday, April 8th, 2020 AT 7:59 PM
STEVE W.
  • 13,640 POSTS
AUSTIN ROBBINS, Could you please use this link: https://www.2carpros.com/questions/new
to ask this as a new question? Thank you.
Thursday, April 9th, 2020 AT 5:04 AM
