HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Ram
Engine
Symptoms
Misfire
1998 Dodge Ram miss at low speeds about 40km
RONALD CABANAW
MEMBER
1998 DODGE RAM
V8
2WD
AUTOMATIC
235,237 MILES
When driving about 40km the truck misses and I got to let off then hit the gas more then it seems to be ok
Thursday, October 21st, 2010 AT 11:49 PM
MECHANIC
Engine running rough or misfiring can be cause by the following:
1. Defective spark plug
2. Inadequate spark/coil, defective spark plug wire.
3. Lack of compression
4. False air leakage.
5. Faulty fuel injectors.
6. Insufficient fuel pressure.
7. Contaminated fuel.
8. EGR valve that is leaking.
9. Oxygen sensors.
10. Throttle position sensor.
11. Idle air control valve.
SPONSORED LINKS
Thursday, October 21st, 2010 AT 11:55 PM
Please
login
or
register
to post a reply.
Related Engine Misfire Content
1998 Dodge Ram What Would Cause Misfire On Cylinder 3...
Engine Mechanical Problem 1998 Dodge Ram V8 Two Wheel Drive Automatic What Would Cause Misfire On Cylinder 3 & 4 On My 5.9 Engine?...
Asked by
jgme67
1998
DODGE RAM
VIDEO
Intermittent Misfire
Instructional repair video
GUIDE
Misfire Random Code P0300
The world of automotive diagnostics can be complex, with numerous codes and potential issues to keep track of. One of the more common engine diagnostic codes is P0300, which...
1998 Dodge Ram Skipping
My Truck Skips Very Bad When It Is Idling. The Engine Light Is On. And The Code Says That One Of The Cyclinders Is Misfiring. But I Put In...
Asked by
ascamarorsss
1998
DODGE RAM
1998 Dodge Ram Various Surging Or Skipping
Mostly Noticeable At Highway Speeds, Engine Surges Or Skips At Various Times. Some More Intense Then Others. Had A Similiar Problem Two...
Asked by
DAVERS54
1 ANSWER
1998
DODGE RAM
1998 Dodge Ram Misfire
1998 Dodge Ram 2500 5.9 Bad Misfire. Engine Check Light Came On And Also The Abs Light, Then The Speedometer Quit Working. I Have Changed...
Asked by
tex1234
1 ANSWER
1998
DODGE RAM
1998 Dodge Ram
My Truck Is Bogging Down. When I Press On The Gas It Seems Like It Is Not Getting Gas And Then It Goes. The Check Engine Light Came On And...
Asked by
motherbear67
1998
DODGE RAM
VIEW MORE
SPONSORED LINKS
Online car repair manuals
