1998 Dodge Ram Skipping
128,300 MILES • V8 • 4WD • AUTOMATIC
ASCAMARORSSS
  • 5 POSTS
My truck skips very bad when it is idling. The engine light is on. and the code says that one of the cyclinders is misfiring. But i put in new wire and a distributer cap in. When the truck is moing between 25 - 30 mph it will also make a light popping noise
Jan 12, 2009 at 2:32 PM
  • 110,248 POSTS
Did you replace the wires and the rotor?
Jan 15, 2009 at 9:35 AM
ASCAMARORSSS
  • 5 POSTS
Jan 15, 2009 at 1:22 PM
  • 110,248 POSTS
Hi:
If everything is new, I need you to pull the plug from that cylender and let me know what it looks like and while the plug is out, do a compression test on that cylender. The popping noise is making me wonder if you have a burnt valve.
Let me know what you find.
Jan 15, 2009 at 2:42 PM
