1998 Dodge Ram hood release
ST1RCBR6
Interior problem
1998 Dodge Ram Two Wheel Drive Automatic
the hood release does not work. How can i release the hood?
Oct 15, 2010 at 9:32 AM
BLUELIGHTNIN6
  • 16,542 POSTS
is the cable broken or handle broken? if not than have a helper pull on release handle while you jar on the hood near the lever, it should pop open if the latch just needs lubricated. if the cable is broken though you may have to go up through the grille with a screwdriver to flip the lever manually.
Oct 15, 2010 at 9:34 AM
ST1RCBR6
thank you i will try
Oct 15, 2010 at 9:42 AM
