1998 Dodge Ram
86,000 MILES • V8 • 4WD • AUTOMATIC
MGRAFFITO1
When accelerating, the engine has a lean pinging sound, then the "check engine" light comes on.
The computer scan says "MISFIRE CYLINDER EIGHT"
I did a compression test on that cylinder and it was fine. The plugs are new.
I have replaced the cat converter, plenum pan gasket, wires, cap, and rotor.
Can it be the PCM? I read that there is an older TSB regarding reprogramming the PCM for these symtoms.
Help!
I neglected to mention that I also pulled the injector and the screen was free from any debris.
Although, the schrader valve on the fuel rail blew out a foamy, bubbly fuel when I depressed the stem. Is this normal? Or is it part of my problem???
Feb 21, 2009 at 10:37 AM
BMRFIXIT
  • 19,053 POSTS
Check fuel injector
check injector pulse
Feb 21, 2009 at 10:56 AM
MGRAFFITO1
Feb 21, 2009 at 11:16 AM
BMRFIXIT
  • 19,053 POSTS
Switch the injector with another
check if code move with the injector
check if you have a pulse on that injector
Feb 21, 2009 at 11:40 AM
