1997 Dodge Ram Starting
ERNIERUDDOCK
  • 1997 DODGE RAM
  • V8
  • 230,000 MILES
After driving my truck for about thirty minutes, to the point that it is up to operating temperature, when I shut it off, it will not restart even though the engine turns over. I changed the fuel pump thinking that was the problem, but it continues to not start. After the truck cools down for about an hour, it will start right up and go for as long as I need it to.
Wednesday, May 20th, 2009 AT 7:35 PM
BMRFIXIT
  • 19,053 POSTS
Check for spark
suspect coil
and or crank position sensor
turn key on check engine light on
crank engine does check engine light on go off
also mark and switch relays around
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Wednesday, May 20th, 2009 AT 10:08 PM
