1997 Dodge Ram overdrive
JAB1960
Transmission problem
1997 Dodge Ram V8 Four Wheel Drive Automatic
rpm wont drop when overdrive switch is activated.switch seems to be working fine.At approx 80-90 klms/hr I normally switch to overdrive but the rpm's are staying at 2800-2900,and climb the faster I go.Have checked the throttle valve cable and acclerater cable and all seems fine.Fluid is up and nice color.No burning smell.All other gears are great.Have disconnected the battery to reset the P.C.M.I'm stumped.Any help on this would be awsome.Thanks in advance for your help.
Dec 7, 2009 at 3:14 AM
CARADIODOC
  • 34,414 POSTS
The transmission won't go into overdrive if the coolant temperature is too low or too high or if the transmission temperature is too high. A temperature sensor that is reporting an incorrect reading could cause your symptom. An unplugged electrical connector on the transmission will prevent overdrive from turning on too.
Why are you switching overdrive on and off manually? Normally it is left alone. It should only be switched off when pulling a heavy trailer. I heard of someone turning the overdrive off every time she climbed into her van. She misunderstood the instructions from the salesman who sold her the van. What a pleasant surprise she got when her fuel mileage shot way up.
The only thing disconnecting the battery will do is erase the stored fuel trim data that took a long time to develop and memorize. Any diagnostic fault codes in the engine computer's memory will also be lost. Any stored codes should be read and recorded before disconnecting the battery to prevent losing that valuable information.
Your mechanic can connect a hand-held computer to access information from the engine computer. It will show if it is commanding the overdrive to engage. If it is sending the command, but the transmission isn't going into overdrive, there's an internal mechanical problem. If the computer never commands overdrive to turn on, look for a sensor or switch problem.
caradiodoc
Dec 7, 2009 at 7:20 PM
