1997 Dodge Ram engine wont start
80,000 MILES • V8 • 4WD • AUTOMATIC
RICHS46
  • 11 POSTS
it was -20 out and i tryed to start my truck and it fired a few times but would't start, batt. went down so i put charger on it with 200 amp boost, still woudnt start, i fugured the oil was too thick i changed it to a thinner oil , now it cranks over fast but still won,t fire...... i tryed starting fluid no help it seems like there is no spark
Jan 16, 2009 at 5:29 AM
  • 75,988 POSTS
Check fuse no.9 10amp if okay-test the ASD relay it powers the coil
Jan 16, 2009 at 5:43 AM
RICHS46
  • 11 POSTS
that fuse is good and i swaped the relays around
Jan 16, 2009 at 5:55 AM
  • 75,988 POSTS
Have helper turn key to run while you listen to the ASD relay did it click
Jan 16, 2009 at 6:03 AM
RICHS46
  • 11 POSTS
i dont have anyone here to help me but i had the key in the run position and pluged the relay in and didnt hear no click. i just checked for power at the coil too.... no power there
Jan 16, 2009 at 6:12 AM
  • 75,988 POSTS
I want you to check for power at the fuel pump connector dark green and black wire -do you have it
Jan 16, 2009 at 6:55 AM
RICHS46
  • 11 POSTS
i cant find the connector for the fuel pump.....i do smell gas at the tail pipe when i crank it over
Jan 16, 2009 at 7:29 AM
  • 75,988 POSTS
Do you know how to check for spark?
Jan 16, 2009 at 7:58 AM
RICHS46
  • 11 POSTS
when my wife gets home from work i can have her crank it over and i can check for spark
Jan 16, 2009 at 8:07 AM
RICHS46
  • 11 POSTS
no spark at the coil when my wife cranked it over
Jan 16, 2009 at 9:17 AM
  • 75,988 POSTS
Test the ASD relay and get back with me.
Jan 16, 2009 at 2:38 PM
RICHS46
  • 11 POSTS
ok i replaced the asd relay with a new one still no spark
Jan 17, 2009 at 2:08 AM
RICHS46
  • 11 POSTS
i rented a scan tool and i get an error message when i try ro check for codes, it says verify the control module is not defective
Jan 17, 2009 at 4:19 AM
  • 75,988 POSTS
Your ignition system is it a distributor/DIS or COP?
Jan 17, 2009 at 6:46 AM
RICHS46
  • 11 POSTS
it has a distributor, i just checked and i have power to the ecm and both ground wires are grounded i think i have a bad ecm
Jan 17, 2009 at 6:54 AM
  • 75,988 POSTS
The ECM are you refering it as the computer or the ignition control module?
Best test the coil, distributor pick-up coil, camshaft and crankshaft sensors before you think about the brain its expensive-get back and let me know
Jan 17, 2009 at 8:08 AM
RICHS46
  • 11 POSTS
the check engine light is not coming on when i turn on the key and no power to the fuel pump and no power to the injectors or the coil , so im thinking its the computer, i found a rebuilt on on ebay for$189. w/exchange
Jan 17, 2009 at 9:00 AM
  • 75,988 POSTS
You're getting down with the computer-If the ASD relay is not energized by the computer you'll lose all 3 of them-
Jan 17, 2009 at 9:11 AM
RICHS46
  • 11 POSTS
i replaced the ecm with a new one and my truck started right up.......thanks for your help
Jan 24, 2009 at 8:13 AM
