1997 Dodge Ram
TATERTOT
  • 1997 DODGE RAM
  • V8
  • 150,000 MILES
I have been having a problem with my truck pulling to the right really bad I have changed my pads rotors, calipers, ball joints upper and lower, wheel bearings, rear shoes and brake cylinders all done on both sides and all new parts could it be a bad break line can someone please help!
Friday, October 30th, 2009 AT 11:09 PM
  • 110,052 POSTS
Does it only pull when you use the brakes? Also, safely raise the front of the truck and have someone spin the tires when you hit the brakes. Does the brake on each side respond? Do the release as soon as the brakes are released? Have you checked the alignment?
Saturday, October 31st, 2009 AT 3:50 PM
