1997 Dodge Ram steering gear leaks
1997 DODGE RAM
99,000 MILES • 6 CYL • 2WD • MANUAL
KENDEPIN
My steering gear assy. is leaking fluid from where the pitman arm connects to. does this mean my steering gear is in need of replacement or could it just be a seal?
Mar 15, 2008 at 7:41 AM
BMRFIXIT
  • 19,053 POSTS
I ve always replaced it as a unit but i belive you can buy a seal kit
Mar 15, 2008 at 8:00 AM
MERLIN2021
  • 17,250 POSTS
You can try replacing the sector shaft seal, use the entire kit...comes with new seals and metal spacers...remove the pitman arm, I suggest using the tool designed for it, then remove the snap ring, then place a bucket under the shaft and start the truck, if the seals dont' blow right out turn the wheel to a stop briefly, dont keep it forced over, and don't run it after the seals are out...have a friend help while someone watches, keep face out of the area, major hydraulic pressue and serious injury will result!
Mar 15, 2008 at 8:03 AM
