1996 Dodge Ram Shifting problem
MARKANDTERRYVAUGHN
  • 1996 DODGE RAM
  • V8
  • 4WD
  • 216,000 MILES
Developed leak and stopped shifting at the same time. It will shift into 2nd, some times into 3rd, but not into 4th. I changed the filter, reset the computer and it still won't shift. Before I pull the transmission to replace the front seal, would the seal cause it not to shift or is it an electronic problem? Or maybe both or something I haven't thought of?
Monday, February 22nd, 2010 AT 8:04 PM
DAVE H
  • 13,384 POSTS
Hello .. thanks for the doantion .. much appreciated
Fluid loss can cause a non shift .. loss of pressure from fluid loss can cause a non shift ..it could be low fluid causing the non shift .. but it also could be another fault altogether .. you really need to have the trnas checked at a transmission shop .. if it is an electrical fault on the transmission it should be storing fault codes which do not always display the CEL ..
hope this helps
http://www.2carpros.com/forum/automotive_pictures/266999_AAA2_995.png
Wednesday, February 24th, 2010 AT 9:01 PM
MARKANDTERRYVAUGHN
I tried to get the code once but the check engine light wouldn't flash at all. I will try again and I will check with a local shop to see about getting it in. Thanks for your help Dave.
Wednesday, February 24th, 2010 AT 9:48 PM
2 LINSEY
  • 287 POSTS
We appreciate your donation and look forward to helping you in the future. Thank you
Tuesday, March 2nd, 2010 AT 12:25 PM
