1996 Dodge Ram keeps dying
154,000 MILES • V8 • 2WD • AUTOMATIC
SANPADRE
doesnt do it all the time. oil pressure drops then it dies. what should i check?
Oct 5, 2010 at 9:55 AM
  • 110,244 POSTS
Has the check engine light come on? Have you checked for vacuum leaks? Fuel pressure?
Jun 1, 2019 at 8:09 AM
SANPADRE
oil was changed shortly before i bought the truck. notice yester day that the oil pressure would drop, before dyin. drop down below 20. checked oil, and noticed it was over filled. about 1 1/2 above the full mark. also put 10 w 40 and an oil treatment in. check engine light was on for the first couple of days, then went off. would to much oil cause the dying?
SANPADRE
if it was a vacumme leak, wouldnt it happen all the time? its fine for a day or two, then starts dyin again
  • 110,244 POSTS
Hi:
A vacuum leak really affects the engine at an idle, unless it is a really large leak. As far as your question, based on where the vacuum leak is, it may or may not cause it all the time.
Your primary concern seems to lean toward the oil light. As the engine's RPM's drop, oil pressure will too. Therefore, it is normal for the pressure to drop as the engine slows. If it is running really low ready to die, the light could come on.
Now, having 1 1/2 quarts too much oil in the engine can cause leak problems, so I would recommend removing the excess. Also, I believe the manufacturer recommends 10W30 for your vehicle.
Finally, I still think you either have a vacuum leak issue, or the idle air control motor is bad. However, I can't be sure until the check engine light is on and you have the computer scanned for codes. If the light comes on, take it to a nationally recognized parts store and have them scan the computer. Most will do it for free. Also, keep in mind, if there really is no oil pressure, the engine will start ticking and knocking. If you hear that, shut it down ASAP.
