1996 Dodge Ram 1500
KCTHACKER
I have a 1996 Dodge Ram 1500. It will not go over 15-20 mph. And when you push on the gas it doesn't make the normal running sound it is a loud noise. Any idea on what might be wrong. Your help is greatly appreciated.
Jun 26, 2007 at 7:56 AM
BRUCE HUNT
  • 3,754 POSTS
If you did the work yourself, go back through the work and look for a possible connection that didn't get reconnected or not seated properly.
Jun 27, 2007 at 1:45 AM
DR. RAMSKOV
[quote:3ad0bcd076="Bruce Hunt"]If you did the work yourself, go back through the work and look for a possible connection that didn't get reconnected or not seated properly.[/quote:3ad0bcd076]
Thank you we will go throught the entire process again and check for connector problems.
Dr R
Jun 27, 2007 at 5:09 AM
