1995 Dodge Ram wont start
WEBBSWRECKING
  • 1995 DODGE RAM
  • V8
  • 4WD
  • 152,000 MILES
The truck cranks, fires, and gets fuel but wont start unless held to the floor. It wont stay running just will rev once acks like it is not getting enough fuel I have a snap on scanner but it shows no codes. We changed the fuel filter/regulater, timing chain, plugs, made sure wires on right only thing scanner says I think could cause this is cam sencer not reading and timeing is -4 degrees some days will fire with nogas pressed fuel pump works and we changed fuel any help would be nice on this head aik thanks
Saturday, December 26th, 2009 AT 11:51 PM
Check the coolant temperature sensor, idle air control motor, throttle position sensor and manifold absolute pressure sensor. When the timing chain was replaced was the cam and crank marks are all aligned and no.1 piston on compression stroke/TDC
Sunday, December 27th, 2009 AT 12:07 AM
WEBBSWRECKING
We changed the tps that did nothing I hooked the scanner back up the cam sencer is working now is the temp sencer that big of a deal that it wont let the motor stay running? The scanner says the fuel is rich starting fluid floods it out have good compression is there anyway to test the map sencer? I think that could be the problem but for 60 dollies I want to make sure I got a lot ruled out thanks buddy but any more ideas?
Monday, December 28th, 2009 AT 3:18 AM
Is there anyway to test the map sensor?
Go to this link:
https://www.2carpros.com/topics/electrical/map-sensor--2
Monday, December 28th, 2009 AT 4:49 AM
