1994 Dodge Ram my 1994 Dodge Ram 350 van wont start.
SCDALLAS03
  • 1994 DODGE RAM
  • V8
  • 150,000 MILES
We tried replacing distributer cap, could not find the fuel pump relay
Sunday, November 1st, 2009 AT 6:26 AM
1994 Dodge Ram my 1994 dodge ram 350 van wont start.
Do below to determine if the problem is fuel or spark
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
Sunday, November 1st, 2009 AT 12:47 PM
