1989 Dodge Raider runs for a little, then stalls
120,000 MILES • 6 CYL • 4WD • AUTOMATIC
JKELLER88
Just bought 1989 Raider with Mitsubishi engine. It runs for a little bit, then shuts off, then won't start again until about a half hour later. Fuel pump and filter is new, along with distributor. Can you please help me?
Aug 22, 2009 at 9:51 AM
  • 75,988 POSTS
Next time it won't start-check if its fuel or spark related-do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Aug 22, 2009 at 9:56 AM
