1989 Dodge Raider repleaced water pump
1989 DODGE RAIDER
DUANE WALKER
Engine Mechanical problem
1989 Dodge Raider 6 cyl Four Wheel Drive Manual
i replaced the water pump,after putting all back together it wont start.it turnes over fine but wont fire.i checked the spark and it has spark.i have a feeling its not getting fuel but no way to check if it is as its fuel injection.it could be the timing but i made sure i didnt turn any cams or crack while i was doing the replacement.what can i do?
Dec 10, 2008 at 11:16 AM
  • 110,244 POSTS
Hi:
You need to check for fuel pump pressure. Have you checked to see if it is getting gas?
Mar 12, 2009 at 9:43 AM
