Dodge Transmission Slippage
DODGE
NMLYNN
Why does a transmission slip?
May 24, 2007 at 9:28 AM
E40WATER12
  • 522 POSTS
Why does a transmission slip, Its due from excressive wear inside the transmission, Gear bands, That wear thin, In which it comes to a point, When you push the gas pedal the metal bands squeez together in which allows the car to pick up speed. Usually tranny fails from lack of maintance done on the fluids and filter replacement.
May 24, 2007 at 7:26 PM
Suggested Repair
Service the transmission fluid and filter. Slippage is typically from worn internal bands after neglected fluid and filter maintenance; if bands are already worn thin, the transmission may need internal repair.
Conversation Summary
The owner asked why a Dodge transmission slips. The expert explained that excessive internal wear, especially thinning gear bands, causes slip under acceleration, and that failure usually follows lack of fluid and filter maintenance.
