Dodge 3500 Overheating at Low Speed
DODGE
RICK MORRISON
I have a 1000 Doge 3500 4x4 with a 5.9 cummins engine, the trouble is this: iI use it as my welding truck and everytime I am travelling at a low speed or logging thru mud in low gear (sometimes just driving up a hill) the temperature gauge starts to rise to the point where I have to stop a let the vehicle cool down a bit or open the hood. Can you please help me determine what might be causing this?
Apr 17, 2007 at 7:55 AM
SERVICE WRITER
  • 9,123 POSTS
Is the coolant full?...I know sounds too simple, but gotta ask.
Apr 17, 2007 at 3:20 PM
RICK MORRISON
[quote:a2b399fd6d="Service Writer"]Is the coolant full?...I know sounds too simple, but gotta ask.[/quote:a2b399fd6d]
I asked yesterday about my truck getting hot when going up steep hils and in low gear - yes the coolant is full. I have taken it too many mechanics and no one can seem to figure it out - any other ideas you have i may look at.
Apr 18, 2007 at 3:36 AM
BENDARE2
  • 13 POSTS
[quote:99b229c07c="Rick Morrison"][quote:99b229c07c="Service Writer"]Is the coolant full?...I know sounds too simple, but gotta ask.[/quote:99b229c07c]
I asked yesterday about my truck getting hot when going up steep hils and in low gear - yes the coolant is full. I have taken it too many mechanics and no one can seem to figure it out - any other ideas you have i may look at.[/quote:99b229c07c]
Another simple question......check the fan/ electric or belt-clutch driven?.....is it running?
Gotta eliminate the 'easy' stuff first, I guess.......Ol'Ben
Apr 18, 2007 at 6:01 AM
SERVICE WRITER
  • 9,123 POSTS
Waterpump impeller problem on these causing a flow problem have been mentioned to me. Use a new pump, may want to consider an OEM one. Also heard of restricted flow in the radiators.
Apr 18, 2007 at 7:24 AM
Suggested Repair
Confirm the cooling fan is operating. If coolant is full and the fan works, replace the water pump with a new, preferably OEM, pump because a failed impeller can reduce coolant flow. Also check the radiator for restricted flow.
Conversation Summary
The owner of a Dodge 3500 4x4 with a 5.9 Cummins said the temperature rises at low speed, in mud, in low gear, or on hills, requiring stops to cool down. Coolant level was confirmed full. A contributor suggested checking whether the fan is running, and the expert noted possible water-pump impeller failure and restricted radiator flow, recommending a new OEM pump.
