1996 Dodge B1500 Stalls and Backfires
1996 DODGE
GMAC
I have a 96 B1500 van 174k v6, it stalls at anytime then starts right back up and off i go, black smut area by my exhaust pipes, slight backfiring, recently replaced fuel filter. whats going on?
Mar 4, 2007 at 12:33 PM
  • 75,988 POSTS
[quote:d441c9c18c="Gmac"]I have a 96 B1500 van 174k v6, it stalls at anytime then starts right back up and off i go, black smut area by my exhaust pipes, slight backfiring, recently replaced fuel filter. whats going on?[/quote:d441c9c18c]
Have your fuel pressure check-and the following sensors-coolant temp.,throttle position, Idle air control system and MAP or MAF sensor.
Mar 4, 2007 at 1:00 PM
Suggested Repair
Check fuel pressure and test the coolant temperature sensor, throttle position sensor, idle air control system, and MAP or MAF sensor.
Conversation Summary
The owner of a 1996 Dodge B1500 cargo van with a V6 reports intermittent stalling that restarts immediately, black soot near the exhaust, and slight backfiring after a recent fuel filter replacement. The expert recommends checking fuel pressure and the coolant temperature, throttle position, idle air control, and MAP or MAF sensors.
