1999 Dodge 1500 Stalls in Gear
Hey Dean,
What is the original symptom? start and stall hot? cold? does not matter. Was there a check engine light when this started? More info and we can help ya better!!
Chris
Dean,
Sounds like you may have an IAC (idle air control) issue. Heres a quick way to reset it and see if this is the problem. Disconnect both negative and positive battery cables from the battery. Rub the 2 cable ends together for 5-10 seconds. Reconnect the battery cables and turn on the key (don't start it) for 20-30 seconds. turn the key off for 20-30 seconds and then start the truck. You may have to "feather the gas" for a little till the IAC picks up idle control. If the IAC controls the idle normally then you should be all set. If not I'd have to recommend taking it to a trusted shop for diagnosis and repair. hope this helps!
Chris
P.S. by doing this test you basically reset the PCM, idle control and fuel control settings to factory specs.
Suggested Repair
Reset the idle air control and PCM by disconnecting both battery cables, touching the cable ends together for 5-10 seconds, reconnecting them, turning the key on for 20-30 seconds, then off for 20-30 seconds before starting. Feather the throttle briefly until idle control returns. If the stalling continues, have a shop diagnose the IAC and related vacuum system.
Conversation Summary
A 1999 Dodge 1500 stalls in drive or reverse at idle, with no check engine light. Connecting the PCV vacuum hose slows the idle and causes the stall, while disconnecting it or a smaller nearby vacuum hose lets the truck run. After a new PCV valve did not help, the expert suggested an idle air control problem and a battery-cable PCM/IAC reset, with shop diagnosis if idle control does not return.
