Engine Mechanical problem
1976 Other Dodge Models V8 Two Wheel Drive n/a miles
Dodge 318 has backfire through left bank looking toward the front. IT has headers and i heard a little pop a while back and now , it is worse to the point of not idling. I run a compression test and the cylinders are in intolerance, except the max i could get out of one cylinder on the left bank was 120 psi . Could there be a bad valve causing the backfire even though they are in in tolerance. The compression was from 120 to 150 PSI
Feb 23, 2010 at 7:43 AM
