Engine dies when I put the vehicle in gear
DODGE
ALLSHOUSE
1975 Dodge RV w/ 440 V-8.
The motor seems to run fine, but when I put it in gear the motor dies. I have adjusted the idle, but the only way to fix it is to set it at a rediculously high idle. Any ideas?
Jun 3, 2007 at 11:43 PM
JUNKYMAGI
  • 41 POSTS
I'm hoping this is an automatic..
Does the vehicle jump when you put it in gear and then the engine dies?
Jun 4, 2007 at 10:24 AM
ALLSHOUSE
Yes, it is an automatic transmission. Th only time the vehicle jerks is when I have the idle up real high. The motor also seems to strain a little when I push on the brakes (power assist).
Jun 4, 2007 at 12:24 PM
JUNKYMAGI
  • 41 POSTS
Might have a vacuum leak, have you checked for cracked, leaking lines?
Jun 4, 2007 at 12:41 PM
ALLSHOUSE
I did find the hose disconnected, but I have not done a complete inspection. I will do that today and keep you posted. I really appreciate your help.
Jun 4, 2007 at 1:24 PM
