87 Dodge Omni- Voltage Regulator?
1987 DODGE OMNI
MARTYMARIETTA
I just replaced my alternator last night after the bearings went out on the old one.
Two hours earlier the car ran fine- motor is a rebuilt with less than 5000K. The only issue was the grinding noise from the alternator bearings.
So when I hook everything back up and tried to fire the motor up, it cranks strong but will not start.
When I lightly hit the accelerator a small 'poof' of white smoke lazily comes out of the carb after it almost starts. But the car will not start.
I have read that voltage regulators can do this sometimes and I am going to pick one up tomorrow. I just wanted to know if I may have missed something- such as the tension on the belt being too tight. I have it set with approx 1/2" of play.
87 Dodge Omni
Regards!
-Marty
Oct 17, 2007 at 7:00 PM
Mr. Marty
Better hold on -getting that regulator cuz the regulator has nothing to do with not starting. Unless the battery is no good.
The car can start w/o the alternator/regulator as long as the battery is good.
Best bet is to check for ignition spark by disconnecting a sparkplug wire or 2 and ground it to the engine and crank it over -do you have spark? got spark now look for fuel.
Nov 15, 2007 at 6:31 AM
