Squeaky brakes
NMLYNN
I have a Dodge Neon, 2005, 19382, 4cylinder engine.
My brakes have been repair about 3 mths ago but it is real squeaky anyway. I took it back to the shop to have them looked at, but the squeaking has never went away. Could I need new brakes all over?
May 24, 2007 at 9:04 AM
BOOTDOG
  • 665 POSTS
you can try a different higher grade pads, or turn/ replace the rotors, before that, put brake quiet on the backside of the pad to reduce noise. their is also a brake quiet that you can put on the friction surface of the pad. it absorbs through the pad and stops noise. i just can't remember the name. anyway try using the brake quiet before replacing parts.
May 24, 2007 at 11:28 AM
