1996 Dodge Neon Humming Noise
I drive a manual '96 Plymouth Neon that has about 161K. I'll relate my question to a washing machine. When your washing machine starts the spin cycle, you'll know if it's not balanced by the horrible knocking sound it emits. With my car, the faster I go, the louder she gets. It's just like the washing machine sound, except it's a lot faster and is more of a consistent humming nature. I noted that whenever I drive on a partial incline (when the right side of the lane is a bit higher than the left), she runs QUIET like she's supposed to. But the second it's flat ground, she's back to being loud. My first thought is to have her realigned. Any other thoughts? THANK YOU!!!!! :oD
Feb 21, 2007 at 12:58 AM
Have the wheel bearings checked......SOON! The hum is the bearings pitted, the noise change is because of the pressure change on the bearing. Make sure the ground straps are still attached to the strut when you have the bearing changed.
Obvously have it verified first, but it sounds like the animal.
Feb 21, 2007 at 10:56 AM
Suggested Repair
Have the wheel bearings inspected and verified soon; pitted bearings can cause a speed-related hum that changes with load. When a bearing is replaced, confirm the ground straps are still attached to the strut.
Conversation Summary
The owner of a 1996 manual Neon with about 161,000 miles reports a humming noise that grows louder with speed, similar to an unbalanced washing machine, but the car is quiet when the right side of the lane is higher and loud again on flat ground. The expert says the hum is likely from pitted wheel bearings and that the noise changes with pressure on the bearing. The recommendation is to verify the diagnosis, check the wheel bearings soon, and ensure the ground straps remain attached to the strut when a bearing is changed.
